U-Joint Questions
andhar
Newburgh NY
I have known that my k5 needed U-Joints for a lil while now , anyway I went to autozone today and go a set of "brute force" joints for it, according to the manafacturer they never need to be lubed and have a 1 year warranty.
My question is , is anyone running them and I bought four of them, 2 for the main drive shaft and 2 for the shaft on the front.
Opinions Please.
I've ran them in a few different trucks. Never had one go bad yet. We used to hook chains on dry pavement when we were dumb kids and I never broke one. /forums/images/graemlins/whistling.gif
do I need all 4 tho? and is there anything else I might want to change as a preventative measure.
Since there are three in the front shaft you might want to go get another one.
If you have an 80s truck, with 10 bolts unless your truck is a factory 4 speed:
1-0153 BF at the front pinion
2-3011 BF for the C/V, (x 2)
2-3011 BF for the rear shaft, (x 2)
'70s truck with 12 bolt rear and C/V front:
Same as above except the rear shaft, for which you'll need two of 1-0153 BF.
If you have a non-CV front shaft in your truck, 1-0153 BF will fit every driveshaft location.
Front axle wheel joints are 1-0297 BF
if they "never need to be lubed" why is the warrantee only 1 year?
never = 1 year?
[ QUOTE ]
never = 1 year?
[/ QUOTE ]
The warranty from Neapco is a Limited Lifetime. Autozone simply chooses to no longer honor it.
All Neapco u joints are warrantied for life from the manufacturer.
Autozone gives you THREE MONTHS on the greasables and 1 year on the non-greasables. Buy a Neapco joint anywhere else and it's limited lifetime.
They started doing that last year- however, will still honor anyone who purchased it previously. /forums/images/graemlins/smile.gif
[ QUOTE ]
[/ QUOTE ]
Yes, I know, I've got a record full of lifetime u joints. /forums/images/graemlins/thumb.gif
Unfortunately I am missing the two part numbers I really need now as my driveshafts are all 1 and 1 1/2 ton now and I have a D60 in the front so my axle joints are no good anymore either.
Nope. CV front shafts didn't come until the later years. '76 or so I do believe. Never owned a truck that old so I can't say for sure.
