U-Joints bad?
jeff in co
Colorado Springs
I was working on my driveline vibration with some shim experiments.....it didn't help really so I started looking at the driveline.
If I could move each one "very slightly" this means they are shot, correct?
I assume so but wanted to confirm. :rolleyes:
Thanks!
Shouldn't' be able to move them.
You will notice bad joints taking off from a stop, or abruptly lifting from the go pedal under hard acceleration.
That's what I thought. I went by our driveline shop at lunch and they will put in two new spicer u-joints for $25/ea. Pretty sweet deal I think.....
Do I need to mark the orientation of the yokes at the axle before removing or does it not matter on the re-assembly if it's installed 180 degrees different from before?
No good reason not to mark and install as previously oriented. Necessary...probably not.
