OL BLAZER
Registered Member
Just looked at my ride again and I wish I could post a pic (pay up sucker).It looks like someone tried to weld some kinda spot weld on the sides where the straps bolt on the caps of the ujoints.
sandawgk5 said:Here is what a 203 looks like
And here is what a 205 looks like.
The billet covers and oil tube are aftermarket.
Which one does yours look like.
Ira
He said he got the caps on and there was slack in the joint. He also said that with the straps tight the cap is not held in position. In that link there are 2 joints that have the same cross size but one has a smaller cap than the other by a small amount. Are the caps tight in the shaft yoke?KidJethro said:Takem apart. $20 says you have a needle bearing in the bottom of one of the caps.
KidJethro said:My post from the thread sandawg linked-
From left to right- 1310, 1330, 1350, 1410, 1480-
From left to right- 1310/1330, 1350/1410, 1480-
1480-
1480 is also the same size as a D60 axle joint.
sandawgk5 said:He said he got the caps on and there was slack in the joint. He also said that with the straps tight the cap is not held in position. In that link there are 2 joints that have the same cross size but one has a smaller cap than the other by a small amount. Are the caps tight in the shaft yoke?
Ira
KidJethro said:If he had to use a hammer, I'd say thier tight.
