ciffer
i pulled the driveshafts out of the K10 in the process of replacing the transmission. the U-joint where the rear shaft meets the rear differential and the U-joint where the front shaft meets the fronts differential need to be replaced. i see U-joints listed as w/inside lock ring and w/outside lock ring.
which do i have, does it matter which i buy?
