Ubolt torque Specs...
elks
NW Colorado
After a recent pin issue, I am putting the blazer back together. Need to know the torque spec for the rear u bolts. thanks a bunch. 72 blazer with 12 bolt rear and leaf springs.
As tight as you can get them with an 18in breaker bar with the threads tightened evenly. Then drive it around the block a couple times and tighten them again.
that is what i was told.. i failed for them being loose. i asked him how tight. he said get a pipe and crank them down.. till they dont move.. :whistle:
