UD spring plates
cybrfire said:
These sell for $37 a set for most any applications such as 14 BoltFF, D60, HP60 flipped. Might be a bit more if you are looking to put a really huge axle under your ride. I'm sure there are some really large plates out there. :wink1:
Do you still make the ones for flipping the U-bolts on a HP60? If so, is there any lead time? I assume they use a larger diameter U-bolt for the pesky one near the housing?
Yep, still do them. The larger ubolt is 4"+ on the inside. You also have to make a notch in the casting for the ubolt to seat around the housing correctly.
