K5dreamer said:ok few points noted, the engine calls for 34 degrees of timing, youre only running 12, that would make a big difference.
I assume he's talking about 12* advance at the distributor...with the vacuum port unhooked. The 34* figure is with the vacuum advance hooked up.
When you hooked up the vacuum gauge, you said it was 15" and wandered. I'm not familiar with the edelbrock cam #'s. I assume it is the Performer version...204/214 @ .050, correct? That cam is basically "one size larger" than stock for lack of better terminology. That cam shouldn't have enough overlap to cause the 1-2" wander on the gauge.
Try this: Start the engine & let it idle. Raise the hood, put on a pair of gloves, and pull one wire from the distributor at a time. The engine should "slow down" a bit with each one removed. If you find one (or more) that cause no difference in the idle, you have located the cylinder or cylinders with the problem.
You mentioned the engine feels strong down low. If you have weak valvesprings, this would give you adequate power at low rpm, but power will fall off way too soon. If you have the Edelbrock cam I assume you have, you should have decent power to 5000 rpm. If it has good pwer to say, 3000 rpm, then falls on it's face, I'd look at changing the valvesprings.
With weak (but not broken) valvesprings, you will have a fairly smooth idle. If you do happen to find a weak/dead cylinder with the plug wire test, and the idle is kinda rough, you may have a broken valvespring, bent pushrod (normally you will hear this), or a flat cam lobe. Cam lobe failure/lifer problem is an increasingly common problem due to the newer oils not having the ingrediants (zinc among others) to make flat tappet cams survive and marginal lifter quality.
Do the plug wire check & post your results.
Roy
I'll do the plug wire test in the cool of the morning and see if it's any one cyl. in particular.
I'm not saying you should do the same, just saying that gas engines sucks in the hills for the most part, I got tired of it.
