UHMWPE between leafs
BGKYK5
3/4 ton status
on the crapper...
Anybody running UMWPE in their leaf springs? How thick of material did you use. Just pads at the ends of the leafs or all along the leafs?
A CK5 search on "UHMWPE" results in exactly 4 hits (maybe 5 now :D), two of which are about fairleads and the other two don't mention thickness.
Edit: I am looking at item 76445A764 at McMaster.
The local plastics place sold me a roll of tape; I think it's actually HDPE (yeah, the cutting board material) which is definitely slippery ;) I went lengthwise, as it's a fairly long roll (think duct tape). Unfortunately it's 2" wide tape (if the springs are 2.5", anyway, it's a bit thin) but on the limited testing I've done it does its thing. :dunno:
-- A
Yeah, I can only find UHMWPE in 2" and 3" widths. I could cut down 3", but I think I would just use 2" and call it good.
1/4 inch on each side aint gonna hurt. i would also just do it at the ends whre the leafs actually move.
Talk to jekbrown. IIRC he had good results with it.
I've used the 3" wide UHMWPE tape, I think it was 0.060?? I just cut it to size once it was on the springs.
Anyway, it started to come out on the first trail run. Not enough to require tightening the u-bolts, but nevertheless. That was on a stock rear spring pack where the leaves were freshly painted, and had new teflon end pads. The tape basically didn't stick well. I didn't use it on the front since I got new springs at that time anyway.
My take is that if your spring pack is in good shape, and not rusted into a single hunk of ferrous oxide, the flex is fine without UHMWPE. The springs on my truck easily flex into the bump stops. But keep in mind, I only wheel in the land of no rust...:D
The UHMWPE tape has come in handy for a few other uses, but I won't go thru the trouble of putting it into a spring pack again. Then again, I've got new rear springs now...
