THISISWEIRD
I feel like an idiot for asking this question, but here goes.
I need to replace my ujoint and I know it's much easier to do it with the drive shaft out of the vehicle, but I can't figure out how to do that. The joint at the TC doesn't have straps to release the driveshaft...it appears to be pressed into both sides of the yoke at the TC. If I pull the driveshaft out of the TC (241), won't it leak fluid?
Furthermore, everytime I've replaced a joint, it has the retainer clips on the side opposite the straps (down at the rear end) . Mine doesn't have the retainer clip....looks to be pressed on. Do I just not use retainer clips when I replace the joint?
