...UJoints...
Drey
3/4 ton status
Iowa
All I ever hear is that weak 6.2 cant do anything worthwhile, it doesnt have any power. Well i murdered a Ujoint so it must have some I guess /forums/images/graemlins/thinking.gif
Are there any certain brands you guys would recomend?
Im telling and RJ just as soon as I get a good credit card offer in the mail, Ill sign up to be a member, I also wanna get a CK5 Shirt and some decals so dont thing Im to cheap to be a member.
Btw...I didnt know they still had Post Offices out in Podunk, South Dakota. /forums/images/graemlins/rotfl.gif Just Kiddin Man
[ QUOTE ]
[/ QUOTE ] If you take care of them they don't get weak as easy. I think pre existing damage due to poor care caused your ego boost. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
spicer forged cross joints are the best you get short of CTM type joints.
How often should I grease and how do I tell when I have put enough grease in them?
I broke one with a 305..... I was trying to do a burnout and my brakes are biased very much to the rear (as I found out). The brakes lock up so tight in the rear that the u joint just let go before the tires spun.
Install the non-greasable Spicer forged u-joints. They have bronze bushings instead of needle bearings.Whatever you do, don't try adding more grease in the caps, they are ready to go out of the box. They're in my front end, no worries. /forums/images/graemlins/smile.gif
I got mine from Stephan at ORD. At the time he had them in stock. Call him regarding your axle. I'm sure plenty of places carry them. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
[ QUOTE ]
[/ QUOTE ]
Grease whenever you grease everything else, and grease until it purges from all four bearing caps. If one of the caps will not purge this means you have a problem.
I do not use greasable joints though personally but that debate is endless.
[ QUOTE ]
[/ QUOTE ]
I've got a pair of 5-806x spicers for my D60 and they certainly have needle bearings. This is the best joint spicer makes for this application and it certainly doesn't have bronze sleeves.
/forums/images/graemlins/doah.gif Yes, thats what I have. I know, I'll tell you my boy's were distracting me... /forums/images/graemlins/doah.gif
It's cool. I haven't got mine installed yet...so many damn projects, I'll probably have my 35 spline outers before I go to install my new u joints.
