BBlazerSK5
Registered Member
Here is a huge parts list of an absolutely Ultimate K5 buildup. I started this project during high school, and wanted to build the best K5 possible. The parts were all going to be installed on an '89 TBI K5, but over the last 3 years at college I have not had any time to put this project together, though I have accumulated all the parts. But with my final stretch coming up I have run into a very bad money situation and have to sell these great parts. All prices reflect exactly what I paid for the parts plus or minus 3-4 dollars to round stuff to nicer numbers. Unless you are taking a huge section of parts I will not sell for less than these prices, and shipping is from 06410 (actual cost...no marking up for shipping). I put part numbers in so that you can look up applications and specs for the parts if there are any questions. Paypal accepted, but I will have to add 3.5% to make up for there take. Thanks
Engine
Description (Part #) Price per Qnty (Qnty Available)
Edelbrock complete Performer
Centerbolt aluminum head (ED 60859) $545 (3)
Edelbrock Performer camshaft
kit for 305-350 TBI (ED 3702) $125 (1)
Flex-a-Lite Electric Fan (295) $305 (1)
Engine Works 350 camshaft Gear-Drive (10901) $110 (1)
Comp-Cams Carbed 350 Low
RPM Torque Camshaft kit (12-231-2) $95 (1)
Comp-Cams Valve Spring kit (981-16) $55 (1)
Comp-Cams Valve Spring Retainer kit (742-16) $45 (1)
Comp-Cams Valve lock kit (601-16) $5 (1)
Comp-Cams Valve Seal kit (501-16) $5 (1)
Comp-Cams Push-Rods kit (7812-16) $25 (1)
Suspension
2.5" wide weld-on axle leaf spring perch (pair) (W/I 250) $15 (2)
weld-on shock mount tabs (pair) (W/I 101) $15 (2)
Rancho 9000X adjustable
shocks w/ 13" of travel (RS99012) $85 (4)
EZ-Ride +6" Front Leaf Springs, 73-88
1/2 & 3/4 ton trucks (pair) (18670) $270 (1)
Drivetrain
Genuine Gear Master install kit for Dana30 (G/G 35-2032) $75 (1)
Genuine Gear Master install kit for Dana 44 (G/G 35-2033) $75 (1)
Dana 60 Parts
Genuine Gear Master install kit Dana 60 (G/G 35-2034) $100 (1)
Genuine Gear Dana 60 5.13 gears (G/G D60-513) $130 (1)
4WD Factory Dana 60 35 spline upgrade kit with Warn
Premium lockout hubs and greasable u-joints. $415 (1)
Detroit Electrac, Electric Locker
for Dana 60 4.56+ (DET 915A522s) $900 (1)
GM 10.5" Parts
for '73-88 Corp 10.5" differential (G/G 35-2023) $110 (1)
Precision Gear, GM 10.5in.
14 Bolt Thick 5.13 gears (P/GGM14/513+) $185 (1)
High Angle Driveline, NP241 Slip-yoke Eliminator kit with
output shaft flange to match factory front driveshaft flange. $475 (1)
AZ-Kickin' Offroad disk brake conversion
kit, includes backing plates, El-Dorado calipers,
and stainless steel braided brake lines. $145 (1)
Body
Bushwack Front Fender Flares,
Chevy 81-88 (B/W 40022-11) $175 (1)
Bushwack Rear Fender Flares,
Chevy 73-88 (B/W 40023-11) $175 (1)
ORD Parts
4" Raised steering arm. (TCI-CSA) $70 (1)
Bolt-in steering box brace for '81+
straight axle GM trucks (GU39001-L) $110 (1)
Greasable HD front shackles (GU37011) $90 (1)
Greasable Main Eye kit for EZ Ride front springs (GU37012) $25 (1)
Swaybar Correctio/Disconnect
system for '73+ Straight axle GM's (GU37001) $90 (1)
81-'91 GM swaybar bushing kit (BG05003) $20 (1)
Urethane Transfercase mount for '89 K5 (BG01006) $65 (1)
4" Rear shackle flip kit for
'73+ straight axle GM trucks (GU38010) $185 (1)
1" Zero Rate Add-A-Leaf (pair) (U8003) $40 (1)
Greasable Rear spring bushing kit for 3/8 shackle (GU38003) $70 (1)
Braided stainless steel brake line kit - 7225 (GU0010) $100 (1)
Dana 60 High-Steering Crossover kit for
6" lift (includes all necessary parts). $775 (1)
Engine
Suspension
Drivetrain
Dana 60 Parts
GM 10.5" Parts
Body
ORD Parts
