Wiring diagnosis isn't too hard if you have a proper manual (I don't think a Haynes will cut it) and a DVOM and some experience. If not, it can be a nightmare like this. Think of the diagram like a road map, the power starts one place and goes whereever the road goes until it reaches its destination. As others suggested, unplugging everything on the circuit, and plugging them in one at a time until you find out where your short is in a component.
If you unplug everything, and its still blows, then you have a dead short in the wire. If its an A-B wire, then you can just disconnect it and run a new wire. If not, then you need to follow the wire to its source. From the fuse panel, to the component.
