Undercoating
ArrowheadK5
Northern MN
What kind of undercoating will keep the frame from rusting?
What is everyone using?
"They couldn't hit an elephant at this dist..."
- General John Sedgwick (1813-1864), last words
Everyone here trusts POR15. You should put that not only to the frame, but to the entire underbody. Try <a target="_blank" href=http://www.por15.com>www.por15.com</a>
Hey, nice Transformer under your name.
<font color=purple>//////
<a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
Soon a 454 K5!!</font color=black>
Well POR works well but you need to sand down the frame to bare metal. Eastwood has some stuff for frames that is pretty good from what I have heard, but never used it. I would personally just hit any rust starting on the floor boards with it after grinding/sanding the worst stuff off. I did POR under my truck originally when I got it, to keep more damage from happening. I just got the floor fixed in a couple spots that were bad before I bought it and used Zerorust aerosal spray cans on the bare metal. Much cleaner then brush on IMO.
Hit the rust areas with your choice of stuff...ZR, POR, etc. I nailed the under side areas that were painted and no rust with Restoleom gloss black... s coats and them used a cheapie $2-3 a can undercoating on decently thick. IMO remove any rust if possible... treat the area, and then layer, layer, layer. That's my $.02 worth oin dealing with MN salt
-Mikey
1987 Chevy K5 Blazer- 350 TBI
<a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
I am a child of the eighties and The Transformers will never die in my heart. It's Jazz, by the way.
