How would I go about figuring out how to properly fuse my engine? On my ls swap I'm retaining the factory configuration of the battery to starter, then to the junction block. Also for the battery lug on the alternator will run through the junction block.
Do I need fusible links on both wires? or is just the single wire from the starter to the block sufficient enough to protect the circuits? Isn't the cab protected by one also? What are the locations of the links and amps they are rated for?
The wiring diagrams are useless, they just say "fusible links"
Would getting it running and running a amp meter across each wire be my only solution to find the proper size fuse?
