Cool, so 2.5 all the way around?Ah, the traditional k5 saggy ass
No. After the lift springs settle, it’ll still have saggy ass
Interesting…. Not heard of this option. Do you know if this will work on any lift brand?Zero rate add a leaf from ORD is a good option for the rear.
Yes you will have to raise the rear end. As well as the front.Cool, so 2.5 all the way around?
Yes, you will need to get new U bolts when you do the springs. These bolt to the leaf spring. They can offset the spring center, or just add an inch. Very commonly used with no issuesInteresting…. Not heard of this option. Do you know if this will work on any lift brand?
Understood. I just wanted to make sure that I didn’t need to install a 2.5 on the front and a 3 on the back. Thanks for the clarification.Yes you will have to raise the rear end. As well as the front.
What lift kit are you looking at?
