I'm getting ready to go through the dana 60 I picked up. Inside the housing was some rust and crud so I want to remove the carrier to check things out. I am wondering to what point of replacing stuff do I need to reset backlash and do gear pattern stuff? I would be replacing the caps in the exact same spot as removed with proper torque.
1. If I pull the carrier and everything looks good can I re install carrier with caps in exact same spots, re torque to spec, and be good to go? I would replace oil seals same time.
2. If the carrier bearings need replacement can I switch them out for new ones and re install and be good to go?
3. If the inner pinion bearing needs to be replaced can I re install and be good to go?
I've been going through the gear setup bible. This is something I have never done before but would like to learn how to do. So what better way to lean than to do it.
