bigred88
88 K5, 10 bolt, 31" tires, no lift. My front tires are wearing significantly more on the outside than the inside. I rebuilt the whole front end about 8 months ago, I suppose the wear could have started then but it took a while to be noticeable.
Is there a certain setting that if incorrect would be most likely to cause this? My first assumption was that I didn't have the toe set correctly, so I rechecked that (and it was off a little), but with that set they still are wearing uneven. Both tires are the same, so I can't imagine that it has anything to do with proper ball joint preload or anything that is set for each wheel individually. Unless I managed to set up both of them exactly the same, and wrong.
Also, what is the recommended toe setting? I did that a few months ago, and looked it up then, but it doesn't hurt to ask- maybe I went with an incorrect setting.
