84 K5 – newer TBI motor converted to Edlebrock carb – electric fuel pump in the tank.
I have been fighting a problem with the truck randomly shutting down – like it’s running out of gas. Did a ton of things already, nothing helped. But I think I’m getting close.
My first questions - should the fuel pressure remain constant at ALL times even at idle? I was watching the pressure gauge at idle today and the pressure dropped from 5 psi to 0…. Sure enough the truck would blog and then stall shortly after this happened. That has to be the issue here.
It did this a few times while I watching it…
So it seems my issue is the fuel pump, fuel regulator or fuel rely. By the way.. all of these parts have been replaced in the last year already. Fuel filter was replaced last week when all of this started.
I can change the fuel rely and regulator pretty easy… but don’t want to mess with the fuel pump unless I have to. Any way to tell what part of the fuel system would be the issue?
