Well on my way to Vegas with my wife we were driving her Jeep Liberty CRD so as to get the best mileage.
On the way up a mountain pass leaving our valley I was about to pass a truck and I heard a loud noise that sounded like I had something rubbing on a tire tread, maybe the plastic inner fender well I thought.
The noise lasted for maybe 1-5 seconds but as I got back on the throttle the noise went away. I stopped at the top of the pass (about 2 miles later) and checked for the noise. I found that the drivers side front inner fender well had at some point come loose and rubbed on the tire so I assumed that was the noise so I kept driving. All the other vital signs were good so I thought it was going to be ok to keep going.
As I was coming down the other side of the pass I noticed that when I was coasting and not on the throttle that there was a "rubbing/slight grinding" noise and that there wasn't any engine braking as you would have with the auto transmission in drive and no throttle.
I kept the throttle in a position to not let it grind and we limped it in to the next town. It was there that I realized that I didn't have reverse at all. I noticed that when I put it into park though that there was a grinding of the park pawl. So with all this I guessed that the problem was in the transfer case.
We limped it in to Barstow CA. and I rented a car to finish out trip to Vegas.
On our return from Vegas we dropped off the rental car and had people on standby to come and help in case we broke down on our trip back home in the Jeep.
I took it real easy and it made it all the way back to Bakersfield without any issues and not very much more grinding.
When I got into traffic in town the transfer case decided to shell and not drive in 2 wheel drive. I shifted to 4 wheel high and drove it about a mile further and then it shelled that gear selection, so I shifted into 4 wheel low and drove it on home about 3-4 miles that way. When I shifted into 4 wheel drive it did not bind at all as I was on pavement so I figured the transfer case was toast.
I got home and rasied the rig up and pulled the drain plug and found the oil to look grey but not black. I fished out some plastic pieces from the drain hole so I do not know whether to try to rebuild or just find a used unit to fix the problem.
I also pulled the cover off the rear axle to make sure it was ok and it looks good, so no damage there.
Long story but I figured that someone here would know where to find a NP242 J transfer case or help me decide to rebulid or what my options are.
