*** UPDATED 06/24/11 =Abandon Project Truck SALE ***
NYDIESELDAVE
Penfield, NY
I unfortunately have given up trying to find the time and money to finish my rocked crawler project. This post will be one of many. I'm selling EVERYTHING for the project including the frame and shell (spotless CUCV). Below is this listings for the first few things I have unpackaged. If you are interested in anything list (or anything you may need that I probably have) just drop me a line and we can handle it here. Thanks again and feel free to drop me a line with any question.
*** UPDATED *** UPDATED *** UPDATED ***
Also, just a list of things to come. Drop me a line on any interests:
AXLES / DRIVE SHAFTS:
1985 GMC Dana 44 Front Axle, 3.73 Ratio (6 or 8 Lug) – USED
1983 CHEV Corp 14 Rear Axle, 3.73 Ratio (8 Lug W/Out Drums)
1979 Dana 44 Knuckles (Pair), Drilled & Taped for Crossover) = SOLD
1980 Dana 44 Knuckles (Pair) = SOLD
1983 Dana 44 Spindles (Pair) – USED
1985 Dana 44 Hubs (6 lug) - USED
2009 U-Bolts (Custom), Dana 44 = Set for 1 Axle w/ Hardware- USED
2009 U-Bolts (Custom), Corp 14 = Set for 1 Axle w/ Hardware- USED
2009 DIY4X Corp 14 UD Spring Plates (Primed & Painted) – USED
2002 Offroad Design – Sway Bar Correction/Disconnect Kit - SOLD
UNK Poison Spider Corp 14 “Rock Ring” – Diff Guard - USED
BODY/INTERIOR:
1985 GMC Jimmy Cab W/ Military Frame (M1008)
1991 LT & RT Fenders (NEW A/M IN BOX)
1991 LT & RT Doors (NEW A/M IN BOX)
1985 OEM Radiator Support - USED
1985 Tailgate - NOS Military Surplus - USED
BRAKES:
1991 Hydroboost Brake Booster - NEW Remanufactured = $100
COOLING:
2009 Radiator 6.2 Diesel Radiator (A/M) – NEW = SOLD
1999 Aux Transmission Cooler (B&M) – USED = SOLD
ENGINE / RELATED:
1985 GM 6.2 Diesel Engine (Rebuild 30k W/ NEW Recon heads,) COMPLETE
1999 Injection Pump (6.2 Diesel), - NEW PROFESSIONAL REBUILD
UNK (8) Fuel Injectors, NEW REBUILD (Tested & Calibrated) = SOLD
1983 GM 6.2 J Code Air Intake- USED
2009 Power Steering Pump (A/M)- =SOLD
1985 GM 6.2 Diesel Crank – NEW – (Needs to be polished = Surface Rust)
1985 (8) GM 6.2 Diesel Pistons –USED
1985 (8) GM 6.2 Diesel Connecting Rods –USED
STEERING:
1985 Steering Column w/o Tilt w/ cruise
2002 Offroad Design - Bolt In Steer Box Brace=SOLD
2003 Grade 8 Steering Box Bolts NEW =SOLD
TRANSMISSION
1985 GM 700R4 Trans. (4 WD, 60k on Rebuild w/ New Torque Conv) – SOLD
2005 Northwest FabWorks Dual Transfer Case Adapter = SOLD
1985 GM NP208 Transfer Case (130k Approx), Complete = SOLD
1984 GM NP205 Transfer Case (89k Approx)
1983 GM NP203 Range Box ONLY (Mile Unk), (TH350 Input) – USED =
1983 GM NP203 Input Shaft from TH350- USED =
1985 NP208 to 700R4 Adapter Plate- USED =
1983 NP205 to TH350 Adapter Plate- USED =SOLD
WHEELS:
(4) 15 Inch 8 Lug - Chrome Steel Wheels - USED
(4) 31-10.50-15 Discovery Tires (Less than 5k)
I'm fairly flexable on that thing but I don't know if you really want to pay shipping all the way to CA. That thing is one heavy piece. BTW I should probably add that the case is NOS and has never been installed. I got it from a military surplus place in an OEM box that was rusted to it. Hence the reason I sand blasted it and primed it. I bought it to put together a doubler. (I have all the parts for a doubler but not time to put it together anymore)
By the way, I'm also willing to accept trades (silver, guns, etc). I have everything for a doubler also. I'll be posting soon some new stuff.
local to you. how much for new rad ?
and whats the story on the blazer frame ? price / condition / mods yet ?
How about $250.00 and I have the receipt from Advanced Auto for it so you have a Lifetime Warranty on it. The frame had been media blasted and then painted black. The body is a 1985 Military Blazer body and has no rust on it and I have already welded up the antenna and equipment holes. I was actually just finishing the body work when I stopped on it. I started to trim in the interior metal and jambs in single stage GM Factory pack white. I have almost all the sheet metal for it and they are all new. Right now it has axles under it and all the rest of the interior is already out of it. Its basically a sell right now.
The Doubler kit is new in the box right from northwest. I opened it only to make sure that everything was there. All parts are there in box. PM me with offer.
Doubler Pics
Please PM me with an offers.
Apparently, I have had alot of interest in the doubler kit from NWF. I just unbox it for the first time to take these picture and this is what it is. I had purchased this for a GM NP205 with a figure 8 bolt pattern. (The case is on ebay for auction right now). I will hold all offers until tomorrow morning and will notify the highest offer.
The wheels are 15x10. Yes I do have steering gears. I have one 2 wheel drive that has been sand blasted and painted. I also have a 4 wheel drive one that has not been.
how much for the steering box shipped to 77301 business and how much for the wheels too i don't know if i have enough cash for both though lol
