I'm needing to update to an aluminum radiator for when i get the new engine eventually. It currently has an old 3 row brass radiator with a 28x17" core in it. Can I swap in a 28x19 core sized radiator without a whole lot of issues? Hoping just some new brackets for the top along with a new cover for the top of the radiator? Would the current shroud work with this size radiator ? Trying to get a bit more cooling area and keep the mechanical fan setup if possible. Also would you recommend updating the fanclutch at the same time since I am in there as old one looking pretty crusty ? I have been looking at the HD models and have seen a severe model as well?
