Brett68
Registered Member
Contemplating upgrading from my 90 V2500 Suburban to a early to mid 90's 2500 suburban. I picked up my Suburban for $1100 last year and put in another thousand. The motor(350) has approximately 150k. The intake gasket is leaking coolant at the passenger rear corner, the timing chain is worn and the balancer rubber is deteriorated to the point chunks are coming out. It consumes a quart of oil every 300 miles(around town) and 200 miles on a road trip. The plugs look great and it doesn't smoke. Bizarre. If I rebuild the engine, crate motor, vortec top end, etc. I'll be into it for another 2 grand. The darn thing is only worth 1500 around here.
Rust free Suburbans are plentiful, mileage varies. I've been eyeing a couple of 93-96 K2500 Suburbans with the 454. Prices from $3k to $6k. The mileage is high. The 93 has 175k but appears to be in great shape. I was told to stay with the 94-95 with the 7427 ECM for reprogramming. I haven't gotten into that and doubt I will. I use these things like a tool to do specific jobs. One job coming up is a road trip to either Alaska or Upper Michigan next summer. No overdrive, 373's and harsh solid axle ride doesn't sound fun.
Low mileage does not exist on older Suburbans in Idaho. I realize on the 93 I looked at with 175k it is due for suspension overhaul. But it is cheaper than drivetrain overhaul. I changed out ball joints and steering linkage pitman to idler on my 94 k2500 diesel truck this summer. It had 196k miles. Ball joint rivets aren't fun. It took about 9 hours of labor(2 days) for that job and I had help. Well he did 80 percent. I work on airplanes he works on big trucks. He has the experience.
Sorry for the ramble. I'm probably just trading one set of problems for another. I need a reliable hunting vehicle that won't consume my time with major rework.
What are the major likes and dislikes of IFS equipped Suburbans?
thanks
Brett in Boise
thanks
Brett in Boise
