Not sure which direction of high performance to go with, was gonna start researching it. I do not tow, and it doesn't have any upgrades if your asking about the engine.. stock 350.. it is K5 79 4x4 and all I do is local driving here and there with a occasional trip but nothing further then a 2 hour drive...High performance as in what? Slotted/vented rotors? Pad upgrade? Big brake kit?
Depends on your intended use. Do you tow? What upgrades done to the truck/ whats it weight? Type of driving? Is it a K5 or k30 or in between? Etc.
Sorry - upgrades as in bigger tires, heavy bumpers, roll cage, etc that would add significant weight and require more stopping power. Sounds like the answer is no to the above.Not sure which direction of high performance to go with, was gonna start researching it. I do not tow, and it doesn't have any upgrades if your asking about the engine.. stock 350.. it is K5 79 4x4 and all I do is local driving here and there with a occasional trip but nothing further then a 2 hour drive...
I do have 33 BFG'S on her but that's about itSorry - upgrades as in bigger tires, heavy bumpers, roll cage, etc that would add significant weight and require more stopping power. Sounds like the answer is no to the above.
I would get the middle range grade of pads, new replacement rotors from a reputable company and put it back together. Unless you are looking toward going bigger tires and rock crawling, I would be good with the proper replacement parts. Cheap pads aren't the way to go. Squeal, make lots of dust, don't give good performance.I do have 33 BFG'S on her but that's about it
