I did a search and I found partial answers to my questions. I will be upgrading my points ignition to HEI on my 71 K5 with a 350. I'm looking at the MSD Ready to Run distributor with Blaster 2 coil. Also looking at the MSD 6a box. I understand you don't need the 6a to use the Ready to Run. What are the pros of using both together if any? Cons? I also understand the HEI has clearance issues on our First Gens.? Anybody use the Ready to Run and have clearance issues? I'm also reading that MSD is junk as of late. Anybody seen any issues with MSD? If you recommend another brand like Mallory, what am I looking for in Mallory?
I'll also upgrade spark plug wires and plugs. Any wires/plugs you all recommend? Anything to stay away from? I'm learning as I go along here. I apolpgize if these are redundant newbie questions.
On another note, I will be upgrading the fuel pump as well. What should I be looking for? I'm trying to get a bunch of part numbers and start ordering parts as funds permit.
ummmm, whatever Napa sells ya...
holley if your feeling schmedley fancy pants about it all...
