Upper Aux Position Shock Mount
scoots90245
1/16 ton status
El Segundo
I have a 3/8” spacer in my shock parts box. I can’t remember if it came off the aux shock or stock position shock. I am only using Aux position with Bilstein 5125s
Thanks for any help
Thank You
I’m kinda making them fit that’s why I’m asking One side fairly easy other extremely tight don’t wanna bend mount out of position
The higher position (pictured above) is the auxiliary shock in a quad shock set up and the spacer is typically found on the lower primary position but is use the spacer on any that had a gap (also pictured above). The solid spacer is way nicer visually that a stack of washers.
