upside down shocks
desertrat67
Hawk Driver
Dumfries, VA
Can most shocks be run upside down or are they designed to be run body down? I don't want to get my rear mounts on the axle relocated. Right now the body gets crushed against the axle tube.
most shocks are not able to be mounted both ways. Your standard Rancho or Skyjacker shocks must be body down or they won't function properly.
Rancho 9,000 series can be mounted upside down. /forums/images/graemlins/thumb.gif
[ QUOTE ]
[/ QUOTE ]
"As a rule you should not run a dual-tube shock like this RS9000 upside down. Monotube gas shocks such as a Bilstein can be mounted with the shock can up or down, but most dual-tube shocks will develop an inch or more of “dead space” where an air pocket forms if you mount them improperly. Bottom line: Mount the shocks in the orientation the manufacturer recommends." -4WheelOffroad.com
http://www.4wheeloffroad.com/techarticles/67238/index1.html
my DTs are twin tube, and the manufacturer says its no problem to mount them either way...
j
You better go look at Rancho's website, they say the 9,000 series shocks can be mounted in either direction. /forums/images/graemlins/thumb.gif
[ QUOTE ]
thats doestsh, doetch, doesth, tech right?
[/ QUOTE ]
thats affirmative.
j
[ QUOTE ]
[/ QUOTE ]
I think I've heard you CAN but they operate better in the normal way. I am completely blanking on reasoning so unless someone says otherwise I must be wrong /forums/images/graemlins/wink.gif
