I painted the interior of my truck with urethane paint and it has what looks like micro pores! You can only see them if you put your face like 6” away but it definitely doesn’t look right. I will be painting the outside the same color and definitely don’t want the hole truck to have these. Can someone help me. The truck has epoxy primer and then a couple layers of sealer. Sealer was brought down to 320g before paint. Paint was done last Saturday and I started wet sanding yesterday. I have wet sanded down to 2000g before I cut and buffed a small area to see what it would look like and I’m not happy. All primers and paints were sold to me by the same paint supply shop that told me they would work together. The rubbing compound is by 3m. I did wool, then the black pad then the yellow pad.
