gerber boy
Registered Member
hey everyone.
I'm in the process of putting my 4" lift in, i have the front all done and just finished tearing apart the back, I was putting the rear springs in and put the end with the double wrap to the front of the truck, (stock shackle did not seem to fit it) is that right? i put the shackles on the back with the open end towards the front of the truck and bolted everything up.
When i was looking at it (my blocks are tapered) it looked like it would be pointing the diff down, i turned one block and it still looked that way.
the truck is sitting with the springs just hanging and the shackles pulled forward so to me it seems like it will point the pinion down even further once they have weight on them.
does this sound right and i'm just looking at it the wrong way? or did i mess up some where along the way.
i am putting a 14bsf in but don't have it by the truck to check it.
it's a used 4" kit with add-a-leaf and block for the back, unsure of the brand, guy i got it from thought rancho.
trucks a 77 jimmy, th350 np203
*also the way the blocks came attached to the spring (bolt threw) the long side was to the front of the truck with the double wrap in the front hanger.
thanks for anyhelp.
thanks for anyhelp.
