i think it is a. try one way, and see if the hub locks. if not try the other way.
when the outer cap goes on, does it need clearance for anything that the recessed space provides?
Unfortunately I replaced the wheel bearings on both sides so I installed them both as picture B without paying attention, just based on how I thought they would function correctly.did you have both sides apart? if not, take the cap off the other side and look at it.
A. Not enough tooth engagement with B.![]()
Thanks for the feedback.A. I rebuilt mine last week.
BTW, you made sure the first lockring with the little tab/post on it was situated properly too.. right? I almost overlooked that one!!
