1-tonmudder
I have been looking at USA6X6's website at their Rockwell stuff and found these,
I assume they allow you to use a regular 8 lug wheel,but would they not put the wheels out wider than a stock axle would be.
Has anybody used these,and would I be able to run a set of uncentered H1's.They said their was some welding involved but is there anything else to know about using these.If I go this route I will dump the drums and run pinion brakes.
