Used gears for 14bff install questions
GM Man
Denver CO
Would you run the bearings on some used gears that you picked up out of the jy, or should I replace them? I got the carrier with the gears and the bearings are still pressed on. The rollers and cages look ok, and they spin fine. Any issues I should be aware of, before I install the gears this weekend?
Thanks.
Bearings are cheap. So in other words. I would put in new ones. Same for the races. Might not make much of a difference but why shoot yourself in the foot over maybe fourty dollars worth of bearings?
Not to sound stupid, but when I unbolted the pinion gear from the axle housing I left it as one piece with the yoke still bolted on the pinion shaft. If I remember correctly are there three bearings for the pinion gear?
Anyone know of a site or retailer that I can pick up Timken bearings for this??
Just take the bearing and race (if needed) to any parts store or bearing place and they can cross reference the number.
yeah there are 2 bearings in the pinion support and one in the housing itself that supporst the nose of the pinion..
Chris
