Used general grabbers
That's wear from use not rot. Wouldn't bother me a bit.
Probably the tire they consistently hooked on a rock to climb for a poser pic or something. All the tires on my X have similar wear.
I ran a set of those in the 35-in variety and they were good tires. Those used ones look like they're about 50% gone already though, that's about the time when I unload tires too.
I made the deal. I want to try 37s on my 77 as is, but didn't want to lay out new tire money to find out I don't like the rpm or rub. My kids truck needs tires too, If I like this size Ill get some new ones and the kids truck will get these.
Late to the party, but what’s the date code?
I definitely wouldn’t sweat those cuts. That’s desert/hard use cuts
Are you at 4 inches in the front? If so kick the axle forward an inch and you will be able to save the rear of the fender, after cutting the fang off the front of the fender
