Big6ft6
Will putting compressed air in the spark plug hole cause the engine to rotate?
OK guys, I am going to hook my compressor up to the spark plug hole in my tbi 350 to help diagnose low compression. You want to keep both valves closed during the process. I have the engine rotated to the correct spot to both valves on this cylinder are closed...but suddenly I was worried that if I applied the air it might rotate the engine.
Anyone done this for valve seal replacement to tell me how it worked out? Putting the tranny in park doesn't lock the engine (flexplate) in place does it?
