Just the camper.
Features:
3 Burner Stove
2 1/2 Gal Propane Tank
30 Gal Water tank
Port-A-Potty
Sink with fresh water faucet and Manual Pump Faucet
Clearance lights
Radiant Heater (Propane)
Table that converts into a bed. Sleeps 2 Adults comfortably
3 Way fridge 12v, 120v, Propane
Hydraulic Jack to lift top
Sliding glass side windows
Ac/Dc lighting
Fresh Water hookup
120 hook up
7 pin electrical cord
Battery hook up
3 Hand crank jacks for easy removal and install to your application.
Rubber Bedrail Seals
4 Bed mounts
4 Adjustable chain bolts
This is one tuff camper! The outside is in good shape and old interior wood is in good shape.*
Flooring in good shape, padding too!
Only problem is the last owner lowered the camper with the stainless burner cover up and caused the shelf to crack.
This camper was designed in 1970 to handle the most extreme weather and off road Comfortably!
Not only will you be getting this badass camper, but also get a tuff piece of American classic vintage history with quality Workmanship.*
*Pics and more info in this Thread:
http://coloradok5.com/forums/showthread.php?t=295659
Features:
3 Burner Stove
30 Gal Water tank
Port-A-Potty
Clearance lights
Ac/Dc lighting
Fresh Water hookup
120 hook up
Battery hook up
4 Bed mounts
