shiner2001
Registered Member
I started rewiring the trailer wiring plug on my Suburban today since the housing on the old one was all cracked and ran into a couple spots where I figured I'd come to the experts for some quick assistance. I've only had the Suburban for a couple months, and I'm not super familiar with the factory options that might have come with it. I would assume that since it's a 3/4 ton, it would have come with a beefed up towing package (as far as the electronics). I don't know if the 7-way plug that I am replacing was factory or not, however, and as far as that goes, if the wiring that goes to that plug was factory, either. Here is a picture of what was wired into my old plug:
On the right is your typical 4 or 5 way wiring, on the left are the two heavy gauge wires that are the cause of my question. The red (with a hard-to-see blue and white tracer) and the blue wire are both hot, key on or key off. The white wire on the far right is never hot, even with brakes, lights, key, etc. I don't have a wiring diagram for this truck yet, so if anyone can help me out with these, that would be fantastic. Also, I am curious if my trailer brake controller is a factory option or if that was aftermarket. Here it is:
I have all of my standard trailer wires traced out with my meter (left, right, tail, brake and even the reverse light), but what I am stuck on are the brake controller and the acc wire for the 7-way. As always, any help is greatly appreciated!!
