paulidee33
Newbie
I have a 2004 v6 Holden Lunina Vz automatic it's releasing sparks the same as if a grinder is used and sparks when used on metal. Its sparking only as fare as I can tell its only when im trying to ignite the engine it then sparking or arcing on the passanger side of the engine around near the excuse manafold under a tin bracket protection plate for something that's needing protection from heat I'm guessing. But it's not sparking or arcing every time it's started but on top of that I'm also having trouble starting the engine after it's been driven and seems to be getting worse as time goes past longer and longer it's not fixed but not sure what is the problem?
