74 chev
The motor in my truck is a pretty much stock 350 bored .030 over with an RV cam aftermarket intake and headers.
Ever since i rebuilt the thing it seems to run great until it hits about 2250 RPM where it pretty much does not build anymore power and the Tach will start to flutter a little up to 3000 RPM at which point it seems to max out in RPM's.
I have the most problems with it at highway speeds as when i am in fourth gear doing 65 mph i am right in that 2300 RPM range. The engine because it seems to have issues building power at these RPM's will be very weak and start to back fire on the slightest grade or even when i put my foot into it to try and accelerate.
Could this be a vacuum advance issue?
I honestly don't know how the whole system works or how to test it.
I tried disconnecting the vacuum line to the advance module on the distributer and nothing changed whatsoever, which is what is kind of leading me that way.
