hauling4you
Registered Member
I have found what I believe is the problem with having no vacuum to run the defroster & cruise control. So I repaired the line only to find another, repaired that one and decided to run a test to see if i got it right, started the truck and no oil pressure. The truck runs 15W-40 Rotella T, and it was around 40 deg. outside. O ya it was a cold start also, had no been run for about 2 days. The last trip out I when mudding and was in about 2.5' of water/mud, and light snow. Also of water did splash in the engine bay, could I have killed the stock gauge or the connectors, how reliable are the guages really? Should I just get an after market and hook it up and see then? Any answers would be helpful. I'm completely new to GMC/Chevy diesels, I've always been a ford diesel guy. The second part is sence no one out there seams to have a vacuum diagram for this truck, then how many feet of 1/4" vacuum tube should I buy to replace all the underhood conections, also what other sizes and how much of it should I get? this way I do not havt to take it all off and make my own diagram, I will if need be just wondering if anyone elce has yet.
Dave
Dave
