Vacuum hose question 1979 K10
Justin V
I should've stayed up there
Missouri
On the driver's side, there is a vacuum hose that runs into the cab down by the fuse block. This is a bigger hose as far as vacuum hoses go. On the engine side, it comes off of a tee that also feeds the factory cruise control. I do not know where the other end goes, or what it is for, can any body help me out?
Most likely the brake switch for cruise control. Those were both electric and vacuum.
