When I installed the new carb, and the HEI (much to the delight of everyone on here) my blazer ran. Now the issue I'm having is high idle, even after adjusting the fast idle cam and from a stand still if I put my foot in it, she'll fall on her face until I let off. Once I do that once, she'll pick back up just fine for the most part. Every now and again it will idle down when you come to stop so much that she all but dies. I am about 98% sure its a vacuum leak but haven't started looking yet. A couple questions for you gurus. If I read the vacuum on a gauge, what SHOULD I read if there were no vacuum leaks, and what is the margin of error? (its a sb 350) What I mean is if it is 10" merc, at what point do you say "I for sure have a vac leak?" Also, what is the best vac leak detection liquid? At work we use shaving cream, which works GREAT, but I'm not sure I what that will hurt getting sucked into the engine. Help please?
