Gents, I’m trying to sort a few things out and could use some help/opinions. I’m a pretty novice mechanic but I’m a quick study and I want to learn as I go along this restoration. I just added details on my truck and the build to the builds forum.
First thing I need help on is proper setup for vacuum lines. I noticed the ole girl was marking her territory a bit after my last few drives. I’ve figured out where the leak is coming from as you can see from the pic I posted. This tube leads to nowhere. I’ve done some research on vacuum lines and the proper routing of them but nothing specific to this Edelbrock carb. Also, it appears my Pops removed the vapor canister, probably when he rebuilt the motor about 20 years or so ago. So, trying to understand what I can do/what the proper setup should be. I’ve included some pics that show the lines running to/from the carb. My first concern is stopping the leak but I’d also like to add back the vapor canister. She has a pretty strong fume smell. The carb could be too rich but I can’t help but think it’s related to these lines and the lack of a canister, too.
I also noticed there is a connection on the under side of the breather that isn’t connected to anything. This is pictured, too. Any help/advice appreciated.
