Vacuum modulator line
cj7jeep81
Indiana
I need to replace the vacuum line going to my modulator (and possibly the modulator itself). Should I just use regular vacuum hose, or should I get something different?
yea vaccume hose sould be fine. if your modulator is working right it should never tough tranny fluid just hold a vacume. i think the mobulator was 10 bucks or so for my TH350
I saw autozone had the modulator for $10, but it looks like it might be a pain in the a$$ to replace. I know I need a new line, so I thought I would replace it first. Then when I pull the engine in a few months, I will replace the modulator.
The modulator is easy to change. Just remove 1 bolt from the holddown & it slides out. When replacing the vac line, you can use rubber, just keep it away from the exhaust. Also there is a raised loop where it connects to the intake for a reason...... this is to help prevent fuel vapors from traveling down the vacuum line to the modulator which will cause the diaphragm to go bad. Keep some type of loop here for this reason.
