vacuum pump - oil pump drive or serp belt???
Mikey von
Burney, CA
I have either option open to me. What is the best way to run???
If you're running a serp belt system anyway I say run the serp driven vacuum pump. The serp setup needs an idler in that position anyway...
Hey Max,
interesting thread! does the p400/optimizer still have the gear drive for the vacuum pump or did the just leave it out in the new castings?
Greetings
Flo
It's still there. Those engines use a flush mounted unit that holds the oil pump drive gear. It can be pulled out and replaced with a vacuum pump/oil pump drive assembly though.
Actually you don't need an idler in the vac. pump position. If you get a stock belt from a '93 one ton (no vacuum at all) it will fit perfectly and you can just leave the pump out. That's assuming you're using the serp brackets that mount the A/C on the pass. side, I'm not sure if that's true of the newer models.
good to know. I think I will run the belt driven vac. pump.
