It appears the vacuum pump on my 6.2 is dying,its only making 5" of vacuum--and its making the TH400 not want to upshift right,especially the 2nd to 3rd gear shift--now, the tranny sometimes seems to "slip" into a neutral state,after it finally goes into 3rd gear around 40 mph...it doesn't do that every time,most of the time once it goes in 3rd it stays in fine,and it shifts very firm..
I'm not sure if the trans has been fatally wounded ,or if it'll go back to "normal" once I get the proper amount of vacuum to the modulator...
The VRV valve (vacuum regulator valve) that controls the vacuum signal to the modulator was not working right when I got the truck 11 years ago,and adjusting it proved fruitless,it wouldn't maintain the vacuum signal,you could adjust it and get it to shift properly ,then it'd start dragging out the shifts again..
At the advice of a local trans rebuilder,he suggested I hook the modulator directly to the pump,then screw in the little adjustment screw in the modulator hose nipple till it just bottomed out,then back it off slightly,until the shift points seemed "normal"..he claimed that is what he's done on several trucks similar to mine,and had no comebacks..
I did that,and it has shifted OK since...until recently when the pump evidently started losing vacuum..
I do not know what year my 6.2 is,it was a salvage yard engine someone swapped in before I got it--I see looking on google there was more than one type of pump,some look like a distributor,others bolt on to the intake differently...I tried to get a look at it,but I couldn't climb up in there after getting the air cleaner off to tell for sure which type it has..
I am also disgusted to see a new pump goes for 100+ bucks,so does a VRV valve,which is a lot more than I'm willing to put into the truck right now (would if I HAD the money),so a used one is most likely what I'll end up going with...but how do I determine what year the engine is,so I can get the correct pump?...
I have read online some claim a pump "pod" off a 7.3 Ford is the same thing and can be used on the existing pump drive...anyone here done that?..
I could swap the vacuum pump in my Suburban onto this truck if it were the same,but I'd rather not start cannibalizing that engine either--I need to keep it run-able so I can move it around the yard,and possibly use it to plow if the pickup craps out completely (the Burb has a 700R4 with issues too though,and now has rotted brake lines--for what it'll cost to get a decent trans in that thing and make it roadworthy,swap plates,etc,it'll be about a grand...
I'll have to pray the Th400 isn't fatally wounded once I get another working vacuum pump too...if it is,then the truck will either get taken off the road and be used as a "yard truck" only as long as 1st and reverse works OK,or parted out...
I'm in no shape to be swapping tranny's and engines any more...
I must say the setup GM devised with the pump and VRV valve is lame,mickey mouse at best,in my opinion...I wonder how many good TH400's got fried because of the poor control of the vacuum going to the modulator..
The more I look at the 6.2,the less I like it...this never would be an issue if it had a gas engine...though the engine hasn't given me that much grief,I'm not really fond of it either...
I'm wishing you could still buy a carbed V8 around here for 200-300 bucks like you used to be able too--I'd be happier with a 350 in it right now,gas is cheaper,and this diesel might not last much longer thanks to me not being able to maintain it properly...
Been thinking maybe I should just sell all my junks,and pay someone else to plow my driveway...trucks in worse shape than mine on craigslist with a plow are listed for 1500+ bucks...
)...I'll have to pray the Th400 isn't fatally wounded once I get another working vacuum pump too...if it is,then the truck will either get taken off the road and be used as a "yard truck" only as long as 1st and reverse works OK,or parted out...
