bavarian_blazer
well, the following question is a bit embarrassing to me, so don't laugh...
last year I decided to play a bit with my good ole 6.2, hooked up the wiring and the engine did not run... so i checked the fuel supply, got a diesel bath and very dirty fingers, but after a couple hours i ran out of steam... since that I'm wondering why the dirty old sucker didn't want to start:
glow plugs worket, I checked them about 3 times, fuel supply worked, etc.
but: the vacuum pump wasn't installed, so does that anything have to do with the starting problems?
several other reasons I came up with:
cranking speed to slow
injection pump didn't inject any/enough fuel fuel ( I bleeded the injector lines) =>but I removed all glow plugs and diesel fumes (fine mist/don't know if that's correct english now
) was pushed out of the empty glow plug holes.
so, any vacuum needed for starting? (maybe the egr system blocked something, i don't know?)
I'm looking forward to hear your opinions!
greetings
flo
) was pushed out of the empty glow plug holes.so, any vacuum needed for starting? (maybe the egr system blocked something, i don't know?)
greetings
flo
