vacuum supply line for dash
solace22
kentucky
Long story short, working on getting A/C and vents going, the dash controls dont seem to be working, all the vacuum lines seem to be okay but I noticed an absent "nipple" on the back of the control module where the rest of the lines were connected. I thought maybe this could be the supply line for the vacuum. Where, under the hood, is the source for the vacuum? What am I looking for? Thanks a ton!
I think the line comes from a cannonball looking vacuum reserve tank on the firewall,which gets its vacuum from the intake manifold..
I checked that ball and it has one small line that goes to nothing coming off it and thats its.
However, I did figure it out. It really helps to have engine vacuum when the engine is running. Im crazy. :doah:
But it is weird that nothing is connected to that cannonball looking item. Should there be something?
It looked like there was a T connector off an intake tube that supplied the vacuum and it had a small T on it that had a very tiny orange/black line that was connected to nothing. I presumed it went somewhere on the air cleaner.
If memory serves there is a one way check valve/T thing between the intake and cab. It is positioned (again if memory serves) so that the ball retains full vacuum all the time and is just released when a AC panel control is moved. Other than that the vacuum never fluctuates in the pod. The T thing obviously has 3 ports. So the two that are "connected" inside that T thing go to the cab and the ball, the other end goes to full intake vacuum. Regardless of how high or low the engine is running that ball should retain a steady high vacuum situation inside it. Until the AC controls are moved and it releases it to move whatnot around.
It would help to know what year your truck is. I think they changed from gen 1 to gen 2. I only can tell you from experience with my gen 2 (1975). On my truck, there is a 1/4" vacuum line coming off the intake manifold that goes directly to the large port on the vacuum canister. My vacuum canister, which I believe is OE, has a built in check valve. In the direct center of the vacuum canister, there is a much smaller vacuum nipple that connects a gray 1/8" vacuum line that goes into the firewall. This gray line supplies vacuum to run the entire AC system.
