Dogman12
The breather is leaking oil, I thought it was the valve covers at first , changed gaskets, then changed to EDL aluminum covers and rubber gaskets. I moved the pcv valve to the back and the breather to the front and it is still leaking oil. there is also an excess amount of oil going to the pcv filter and into the air filter and cleaner. My only thought is the air cleaner sucking the oil out of the valve cover? or is there to much pcv presure. any help would be great, this oil leaking onto my headers is not good. BTW it is 85 jimmy with 350 edl carb stock with headers old style heads.
