I suspect that I have some lifter noise on the stock 78 350 V8. The engine sat for a long time. I pulled the valve cover off. I'm not sure what I should be looking for. I have yet to run the engine with the valve covers off. I pushed down on the lifters above the valves and was not able to move the springs. I think that is expected so good there. When I run the engine with the valve cover off I'll check to see if the lifters are all moving. Anything else I should inspect while I have the valve covers off?
