I swapped in a new cam last night and we adjusted it and got it running. drove it for a minute and had a valve rattling so I stopped and re adjusted the valves. I normally do it with the engine running and have no problem but seeing as I put in a new cam I wanted it to fire up and run right off so I didnt kill the cam. its idling really rough, doesnt pull any vaccum and when you put it gear and give it gas the engine doesnt spin any faster. the guy that told me how to adjust the valves said to get the piston at tdc on the compression stroke then tighten till you couldnt spin the pushrod and then go another 1/4 of a turn.
personally I think I got them too tight using this method and need some help. I was always told to tighten till there was drag on the push rod but he said to tighten till you cant spin it. please tell me that I just got the valves too tight and dont have some other serious problem. thanks
