Searched as best as I could, but didnt find what I was looking for. Does anyone know if the disk brake brackets from diy4x would work on a van 14bff? And if not, is there a bracket kit that would work with this rear end?
Yes it will work, the only difference between truck and van width axle is the van axle is 3" wider than a truck axle. The mount is in the same location from the hub so no problems.
